1.674 visninger | Oprettet:  FølgFølg ikke 6 Svar
ny z900 ny z900
Den ser pæn ud. og god performance til pris 129.900
Z900 ABS | First Look Review
Rider Magazine StaffNovember 13, 2016
Replacing the outgoing Z800 in Kawasaki’s naked “Z” bike lineup is the 2017 Z900. The new Z900 carries Kawasaki’s trademark Sugomi-inspired styling, and is built around a new 948cc inline four-cylinder engine and new steel twin-spar trellis frame, for an ideal blend of power, handling and comfort.
Read our 2016 Kawasaki Z800 ABS first ride review
2017 Kawasaki Z900 ABS in Pearl Mystic Gray/Metallic Flat Spark Black. (Photos: Kawasaki)
The new liquid-cooled, DOHC, 16-valve 948cc inline four-cylinder engine was designed to provide smooth power from the mid-range up, with the fun really happening above 6,000 rpm. Four 36mm throttle bodies and sub-throttles ensure mid-range power and smooth throttle response. A downdraft throttle body layout creates the shortest distance possible for the fuel-air mixture.
Read our comparison review of the 2016 Kawasaki Z800 ABS, 2016 Suzuki GSX-S750 & 2016 Yamaha FZ-09
2017 Kawasaki Z900 ABS.
The Z900’s pistons are cast with a special process that enables a lightweight piston on par with forged pistons. Kawasaki promises that all the rider’s senses will be activated when twisting the Z900’s throttle, with an intake designed for enhanced noise and a four-into-one exhaust tuned for mid-range pull and a throaty note.
The 2017 Kawasaki Z900 ABS (left) and its smaller sibling, the 2017 Z650 ABS (right).
The Z900’s gearbox features short ratios for first through fifth gears for strong acceleration, with a sixth gear functioning as a true overdrive for high speed cruising. The assist-and-slipper clutch borrows from knowledge gained on the racetrack and used on the Ninja H2R and Ninja ZX-10R, and creates a light clutch pull while also smoothing downshifts.
The 2017 Kawasaki Z900 ABS in Metallic Flat Spark Black/Metallic Spark Black.
A new high-tensile steel, twin-spar trellis frame uses the engine, which is mounted at five points, as a structural part for increased strength and reduced weight. Upside-down 41mm forks have stepless rebound damping and preload adjustability. The horizontal-backed rear shock and linkage are positioned above the aluminum swingarm for mass centralization and to keep the shock away from the heat of the exhaust. Like the front forks, the shock is adjustable for both rebound damping and spring preload.
Stopping the mighty Z900 are dual 300mm petal discs with 4-piston calipers up front, and a single 250mm petal disc at the rear. ABS is available.
The 2017 Z900 will be available in two colors: Pearl Mystic Gray/Metallic Flat Spark Black and Metallic Flat Spark Black/Metallic Spark Black, for $8,399. An ABS version is also available at a retail price
  • Opsætning af lampe 250 kr.
  • Opsætning af lampe 500 kr.
Kommentarer på:  ny z900
  • #1   12. dec 2016 z900
  • #2   12. dec 2016 virker den ikke unødvendigt tæt på z1000 ?
    føler at det vil være mere fordelagtigt at opgradere den elektroniske pakke, frem for at øge motorstørrelsen, hvis man vil konkurrerer med de tilsvarende mellem vægts maskiner.
    opdateringerne med hensyn til vægt og affjedring lover dog godt smiley
  • #3   12. dec 2016 slaglængden er forresten den samme som z1000. kun mindre stempler
    MOTOR
    Motortype Væskeafkølet, 4-takts rækkemotor. 4-cyl. Slagvolumen 948 cm³ Udboring x slaglængde 73.4 x 56 mm Kompressionsforhold 11.8:1 Ventilsystem DOHC, 16 ventiler Brændstofsystem Indsprøjtning: Ø 36 mm x 4 med ovale sub-spjæld Startersystem Elektrisk Smøring Tvangssmørring, vådsumpsmørring
    BREMSER & AFFJEDRING
    Bremser, forhjul Dobbelt semi-flydende 300 mm bølgeskive, dobbelte 4-stemplede calipere Bremser, baghjul Enkelt 250 mm bølgeskive, 1-stemplet Ophængning, front 41 mm USD forgaffel med justerbar returdæmpning, kompression og fjeder forspænding Ophængning, bag Horisontal Back-Link med justerbar returdæmpning og forspænding
    YDELSE & UDVEKSLING
    Maks. effekt 92.2 kW {125 hk} / 9,500 rpm Brændstofforbrug 5.5l/100 km CO2 udledning 138g/km Maksimal drejningsmoment 98.6 N•m {10.1 kgf•m} / 7,700 rpm Gear 6-trins Endelig fremdrift Forseglet kæde Primær reduktionsforhold 1.627 (83/51) Gearing 1. 2.692 (35/13) Gearing 2. 2.059 (35/17) Gearing 3. 1.650 (33/20) Gearing 4. 1.409 (31/22) Gearing 5. 1.222 (33/27) Gearing 6. 1.034 (30/29) Kobling Våd multiskive, manuel
    STEL & DIMENSIONER
    Rammetype Trellis, højstyrkestål Sti 103 mm Hjulvandring, forhjul 120 mm Hjulvandring, baghjul 140 mm Dæk, forhjul 120/70ZR17M/C (58W) Dæk, baghjul 180/55ZR17M/C (73W) L x B x H 2,065 x 825 x 1,065 mm Hjulafstand 1,450 mm Frihøjde 130 mm Sædehøjde 795 mm Brændstofbeholdning 17 liter Egenvægt 210 kg
  • Jan W
    Jan W Tilmeldt:
    aug 2013
    Følger: 3 Følgere: 1 Svar: 1
    #4   12. dec 2016 Nu er præferencer og smag heldigvis individuelle, men med Z900 har Kawasaki skabt en maskine som virker utroligt indbydende på mig. Efter en ulykke med min Honda fireblade kan jeg ikke længere bære vægt i håndleddene og kørestilen skal ændres til en ikke håndledsbelastende. Elektriske hjælpemidler såsom TC og IMU kunne være rart men så ville prisen nok ryger godt nord for prismærket på 130K og så kunne jeg lige så godt tage en Z1000. Min største bekymring pt er faktisk om lillemor kan få sin klemt sin popo op på det lille sæde bagpå, men det vil en prøvetur til foråret afsløre rimeligt hurtigt smiley
  • #5   12. dec 2016 Sgu en underlig tendens der har været ved motorcykelproducenterne de sidste 10-15 år.
    De har bygget maskinerne større og vildere, men glemt hvad køberne ville have.
    Z1000 har vokset sig så stor, at hvad der basalt set er en opdateret Z750, nu har specifikationer der matcher en 2003 Z1000. Både på motorstørrelse og effekt.
    Ligeledes har Ducati 916 udviklet sig så meget, at lillebroren nu har specifikationer der slår den oprindelige storebror.
    Selv i de mindre klasser er den gået galt. Kawasaki erstattede GPZ500/ER5 med den noget kraftigere ER6, og efterlod et hul. Samtidig er Ninja250 vokset til en 300'er der næsten matcher den gamle 500 model. Og lur mig om Ninja 300 ikke vokser de næste par år, nu hvor både BMW, KTM og Yamaha har 300ccm maskiner, hvis egentlige motorstørrelse er større end det.
    Men jo, den nye Z900 er ganske ok, og prisen ser ud til at være skarp.
  • #6   10. sep 2017 Slet ikk i tvivl om at det er en god maskine...
    Men for fanden hvor hele bagpartiet er grimt, alt for høj, ser uharmonisk ud + den LED X baglygte ligner en børne lampe fra biva. Ville ha købt hvis bagenden så anderledes ud.
ny z900
