Syn på ZX9r Syn på ZX9r
Hej all,
Sorry to ask in English, hope it is O.K. but please reply in Danish.
I have just become the proud owner of a 20 year old ZX9r, and it needs a little fixing up before it can pass syn.
There are some points that I don't want to fix right now because of cost, so would like to know if it will get through as they are?
The bits that I am concerned about are:
No pass light switch (high and low beam switch works, but the right hand switch gear is missing the actual pass light button).
Front breaks make a horrid noise, but plenty of pad left.
Gear change is difficult from neutral to 1st or 2nd (could be V pricy :(. ).
Exhaust has been repaired with filler, but does not leak at the moment.
Also on the look out for parts for the above :).
Any help with the finer points on what has to be fixed before would be very much appreciated.
Tim
og at den kan bremse vel og mærke.
mar 2013
Følger: 5 Følgere: 12 MC-er: 1 Emner: 50 Svar: 509
Tim
okt 2004
Følger: 28 Følgere: 36 MC-er: 6 Emner: 394 Svar: 7.567
http://www.ebay.com/itm/Kawasaki-ZX-9R-Ninja-900-1994-1997-2x-Stainless-Steel-Front-Brake-Disc-Rotor-/161333070537?pt=Motorcycles_Parts_Accessories&hash=item2590334ac9&vxp=mtr
mar 2013
Hej Anders, thanks for the advice, that was a very nice possiblility, and makes much more sence than trying to look at selector arms or splitting crank cases. I was a bit supprised to find that mine was very loose, and quite a bit of ware, more than i had expected for a supposed 50km bike (but it could just as well be a random number :)).
It is a pain in the tit to get the switch gear of the handlebar, the electics join the wireing look inside the clocks, so fairing off again. I was kind of hoping to make a new plastic button as it is the only bit missing, ho hum.
Thanks all for the good advice, in what is for me an administrative labarynth ;).
Tim
maj 2009
Følger: 1 Følgere: 5 MC-er: 4 Emner: 1 Svar: 57
mar 2013
Best
Tim
maj 2009
mar 2013
Best
Tim
maj 2009
mar 2013
Thanks Allan, fingers crossed it wont need any more, the weekend cost about 7000 in parts, but now everythign should be as new (Probably not realistic but can hope).
Althouh it would be nice to take a look at MC-Huset as apparently the rear shocks go after this amount of time and that wasnt on the shopping list.
maj 2009
maj 2009
maj 2009
mar 2013
There was a verbal comment on how my indicator warning light (not the indicators them selves) flashed quickly. It took some time to get it to work at all as the indicators had been replaced with LED lights and needed a couple of new small parts to get a warning light to work as well. But apparently this is not something that will affet the test.
The exhaust pipe repair was fine, but still want to replace it if anyone has a cheap one going, also looking out for a set of locks if anyone has some that fit.
Martin i am still looking forward to seeing a blue zx9 on the streets of Copenhagen :).
Best
Tim
jeg er nu ret sikker på, at hvis kontakten er der, så skal den også virke! Problemet er så bare at ikke alle synsmænd er lige strikse. Det er fordelen ved privatiseringen af synshaller! Eller ulempe om man vil
god vind, og vi ser frem til en oprettelse af en ninja!
maj 2009
It looks like its in okay condition.
Iam taking mine to syn on friday. Hopefuly with no problems aswell
Next time the weather is good, iam ready for coffee at langelinje.
mar 2013
Too true and will do Rasmus :).
Tim
Syn på ZX9r
