Kommentarer på:  motorlampe lyser
  • #1   4. apr 2011 hvad betyder det , når den lyser... temp eller . . ?
  • #2   4. apr 2011 det er motor symbolet der lyser,ikke temperateurlampen
  • #3   4. apr 2011 Her er hvad der står i instruktionsbogen:
    Engine Management System
    Malfunction Indicator Light
    The malfunction indicator light
    for the engine management
    system illuminates when the
    ignition is switched on (to indicate that it is
    working), but should not become illuminated
    when the engine is running.
    If the malfunction indicator light becomes
    illuminated when the engine is running, this
    indicates that a fault has occurred in one or
    more of the systems controlled by the engine
    management system. In such circumstances,
    the engine management system will switch to
    'limp-home' mode so that the journey may
    be completed, if the fault is not so severe that
    the engine will not run.
    Warning
    Reduce speed and do not continue to ride
    for longer than is necessary with the
    malfunction indicator light illuminated. The
    fault may adversely affect engine
    performance, exhaust emissions and fuel
    consumption. Reduced engine
    performance could cause a dangerous
    riding condition, leading to loss of control
    and an accident. Contact an authorised
    Triumph dealer as soon as possible to have
    the fault checked and rectified.
    Note:
    • If the malfunction indicator light
    flashes when the ignition is
    switched on, contact an authorised
    to have the situation rectified. In
    these circumstances the engine
    will not start.
  • #4   4. apr 2011 Har du haft nogle stik afbrudt mend du har slået tændingen til eller startet den?
  • #5   4. apr 2011 Steen P nej det har jeg ikke
  • #6   4. apr 2011 Så er der sikkert en eller anden føler som er stået af !
    Jeg har også haft mit batteri af hele vinteren, men der har ikke været nogen problemer efter det kom på igen.
  • Fanta H
    Fanta H Tilmeldt:
    #7   4. apr 2011 Den kan ske at gå ud af sig selv efter en køretur, hvis ikke skal du på triumph værksted og have den nulstillet, sådan gør nogle triumph modeller, når strømmen har været taget af, næste gang så husk at sætte et par ledninger på kabelskoene med et andet batteri på, så der hele tiden er strøm på.
motorlampe lyser
