881 visninger | Oprettet:
Kawasaki zx 750 h karburator indstilling. {{forumTopicSubject}}
Min kawasaki zx 750'er vil ikke holde sig i gang, selv med fuld coker.
Dog kan den tage lidt omdrejninger, hvis jeg holder for hullerne på hver side af luft filteret.
Så i min verden vil det sige for lidt benzin.
Jeg har haft renset karburatorene, og skruet blandings skruerne helt ind og 1½ gange ud, er det for lidt ?
Nogen der kender grund indstillingen på denne model ?
Kommentarer på:  Kawasaki zx 750 h karburator indstilling.
  • #1   6. jun 2014 Cyklen er fra 89 hvis det gør nogen forskel.
  • #2   6. jun 2014 IIRC should be something like 2.5 - 2.75 for the H1.
    I am not sure you can get the symptoms you describe by mis adjusting them.
    But be careful when you turn them in as they squash a little O ring, and if over tightened that gets damaged.
    They should only be turned in until they begin to get tight, not actually tight (if that is understandable :)). It will definatly run at 2.5 so that may be a good place to start.
    Sometimes the slides get worn on H1s sometime after 50k km, and the middle diaphrams melt sometimes near the cylinder block.
    Best of luck
    Tim
