1.727 visninger
Års bestemmelse af bmw 1200gs {{forumTopicSubject}}
Hej,
Jeg har en bmw 1200 gs adv fra 08. Den er købt brugt af en tidligere ejer og den er registreret som en 08 model.
Kan man ud fra stelnummer eller lign. se om det rent faktisk er en 08 eller om det kunne være en 07 model solgt i 08. Det er fordi jeg sidder og kigger på diverse dele og man kan enten vælge modelår 04-07 eller 08-.
Christopher
jeg løste mit , ved at kontakte min forhandler og give ham stell nr.. og fik så den rette årgang den forlod fabriken...
Følger: 56 Følgere: 59 MC-er: 5 Emner: 110 Svar: 1.789
At its launch in 2004, the R1200GS was 30 kg (66 lb) lighter than the R1150GS it replaced,[3] and produced 100 bhp (75 kW), an increase of 19%. BMW continued to produce the R1150GS Adventure, releasing a final run-out special edition model,[4] before launching the R1200GS Adventure at the end of 2005, for the 2006 model year.[5]
In 2007, upgrades were made to both models for the 2008 model year. Power was increased to 105 bhp (78 kW), a new Integral ABS II anti-lock braking system was released without servo assistance and new options were added including electronic suspension adjustment (ESA) and the Automatic Stability Control (ASC) traction control system.[6][7]
In 2010 model year, both models had a revised cylinder head with double overhead camshaft, increased redline limit to 8,500 rpm, and an exhaust flap to give the exhaust a different tone. Power is increased to 110 hp (82 kW) @ 7,750 rpm.[8]
At the 2012 Intermot show, BMW announced that the 2013 model would be water cooled, deliver an additional 15 horsepower (11 kW), and weigh approximately 20 pounds (9.1 kg) more than the outgoing model.[9]
